Most fuel efficient RPM to shift?
    Once upon a time I owned an 89 accord 5 speed. It came with the owners manual. In the manual it listed the most fuel efficient shift points.
    So now I have an 90 accord 5 speed, but it didn't come with the manual.
    I'm wondering if first, the 90 manual came with this information also, and second if anyone could share it if it did.
    the lower ur rpms stay the less gass u use
    93 EX COUPE, F22A6 turbo project
    http://www.cb7tuner.com/vbb/showthre...45#post1615845
    96 lexus sc300 DD
    http://www.cb7tuner.com/vbb/showthread.php?t=143563
    back from basic.... off to ait.... CB still being worked on i have mad plans for it .. sorry cant tell its on the hush hush for now but all i can say in somewhere around 500 hp soon to come..
      i shift at 2500rpm. but thats if im going slower and cruising. if im driving more faster and around freeways than ill shift at like 3-3500rpm.
        me too..i dont drive to fast
        mines an auto btw.. shifts for me lol
        92 4 Dr Ex-sold/91 civic hatch(bad head)/93 civic vx
          2500rpm when your cruising.
          3500rpm when your feeling agressive.
          I fly by like the coupe grew wings!!!
          Speeding!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          My coupe!!!
          http://www.cb7tuner.com/vbb/showthread.php?t=152924
          Originally posted by Racer_XXX
          Excuse me miss, YOUR FUPA IS IN THE WAY!!!
            I let the computer decide, but its usually around 4k
            wat?
              My 90 owners manual says to shift at 15mph, 28mph, 41mph, 52mph for best fuel economy and emissions control.
                I find that those points are usually around 3k
                  Thanks, that is exactly what I was looking for.
                    Another equally important but often forgot mileage technique is using light throttle applications. If you use 1/2 throttle and shift a 3k you'll probably get worse mileage than someone shifting at 3.5k but barely touching the throttle. I follow the shift speeds in the owners manual and with really light thottle applications I got 35.4mpg on my last tank, that is with a F22B DOHC running on a P39 ECU.
                      That is very true. I got an extra 4mpg with my gas-hog GTP by using light throttle and not letting it go above 2500 (which is high for that V6)
                        So would giving 3rd a lot of gas to get up a hill at around 30 mph be less economical than using second and lighter on gas? I just feel like second is up around 3200rpms which seems a bit steep.
                        Click for my ride thread.
                          It depends on just how much the throttle percentage difference is between the two gears, I shift higher when ascending steep hills to avoid using more throttle in the next gear and due to the quicker loss of momentum when a shift is made while going uphill.
                            in my mazda i would try to shift under 3k. in 5th gear by 40mph
