i have a ? about the psi, a fellow cb7 rider told me that with a f22 stock, that the hightest i can run the psi is 7or 8, is that true,
turbo ? for a f22
Originally posted by C91BLX7 View PostI run 32 PSI in the front and rear.
7-8 can be on a dsm setup or a t3/t4 with a crazy top mount manifold.
Originally posted by murdochyuga View Postc91blx7 are you running that on stock f22 motor are have you tuned it
Look thru the Forced Induction forum, Lots of good stuff there http://www.cb7tuner.com/vbb/forumdisplay.php?f=62
Originally posted by wed3k View Postgood attempt to be a smart ass but he mentioned turbo in his title so you lose.
I've known up to 14psi to be run safely on a stock motor. straightedge is running over 20psi, but that's on race gas, for a track-only car.
It depends on the turbo, the tuning, and the condition of the motor. Most people don't go above 10psi on a stock block, especially if they're running a small turbo like the 14b. The smaller the turbo, the more heat they'll make at low RPMs. Too small, and it's like bolting a blowtorch to your motor.
Originally posted by C91BLX7I run 32 PSI in the front and rear.
Check the Forced Inductions Section.
Call me crazy, but with the DSM setup, you only need a handful of parts, a little know-how and some time and you got yourself a turbo.
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
man i feel like a total newbie with the tire pressure. but thanks for all the help guys now for my next ?.. exhaust for the motor and turbo, becuase my friend with an sti rans a 3 inch pipe with a 4 inch tip, and my other freind in a gsx runs 2.5 inch pipe with a 4 inch tip. does it really matter on the size
wat is this "resistor box" and wat does it do for the injectors?
also check out www.showdownmotorsports.net (or com or org cant remember)
he sells dsm setups cheapbarstow bitches!! middle of BFE
Originally posted by zero View Postwat is this "resistor box" and wat does it do for the injectors?
