Ithink i accidently retarded my timing i was putting on my crank bolt and my timing belt went backwards so now when i start my car its at low idle like at 300 rpm but i never lossened the adjusting nut will it still retard my timing
retard timing
did it skip a tooth?
Still not explained very well, Do you mean the cam gear diddn't move and the crank pulley did?
My 5.7 LS1 Holden Ute
If everything moved, then the timing wouldn't have gone out - everything moves everytime you run the motor. It sound's more like you are referring to rotating the distributor?
Originally posted by Darkcloud View Posteverything moved
Ignition timming, as adjusted at the distributor isn't the same thing as cam timming.
So you retarded your cam timing, or your ignition timing. Your descriptions aren't very clear, as said above.
If it's the cam timing, take everything apart, line up your marks where they should be, and put the belt back on. If it's the ignition, just get a timing light, and follow the instructions on the box.
