What goes down must come up?
    I believe it should be that way, when it comes to power windows. Here's my issue, my passenger side back door suddenly wants to be a bitch and be able to go down, but not back up. It's already bad enough the drivers side back door doesn't work. But this one now?
    What can be the problem here? Do I have to replace the whole motor/assembly or what?
    It's probably the motor. Mine is that way as well, and has been for a long time. I took the panel off an unplugged it, to be sure i didn't put it down accidentally!
    OEM parts fit best, but they're not cheap (and I believe the motor and regulator are separate pieces... assembly is a pain). I always used cheap stuff found online. My back one that I replaced is fine. The front one... not so great.
      The bad part is... the window isn't up all the way. There's like a 1cm opening.
      If I had some window visors it wouldn't be much of a problem.
        Open the door.
        Put one hand on each side of glass.
        Pull up.
        That's what I have to do on my passenger rear side.
          Cb rear windows are goofy as hell. They are cable wich is bound to mess up if not lubed properly. I did what Josh said and then what deev said to insure i didn't do it again on my 92.
          -1991 Honda Accord LX H22a-
            Originally posted by Joshs92ex View Post
            Open the door.
            Pull up.
            hear hear! would always do this if anybody 'accidentally' winds down the window.
            The, I got fed up and did this:
            peace of mind. everytime.
            Click sig to view MR thread
            Links to other rides:
            Honda Accord Euro-R
            Honda Odyssey Absolute
            Honda City I-DSi
            Honda Stream
              spray the hell out of the window/tracks with wd-40 and if that dont work then ud prolly need a new window motor cuz ur old one is burnt out. changing the window motor/regulator is not that hard is like 5 or 6 bolts. i did it on my front one and i got it done in a short period of time the only part that took a little long was adjusting the window so it would seal good.
                Open the door.
                Pull up.
                done it in many cars and did it on the cb when my window regulator was out works the best lol.
                  Open the door.
                  Pull up.
                  lol I tried that. It was embarrassing as hell. I was at the mall and 2 girls, and all my friends who rode with me took the panel off in the middle of the mall parking lot and had to pull it up.
                  I'm gonna have to go through it again and fiddle with it. Maybe tomorrow.
                  Thanks guys for the suggestions!
                    Open the door.
                    Pull up.
                    The honda way
                    Ride: 2002 Lexus IS300
                      get a power window regulator from the JY. So far mine are doing okay, the pass. one is getting slower but it still works. And I've got bigger Coupe windows.
