which mod for more MPG?
    Alright so I'm broke but I want to do more mods to help MPG
    I have $50 invest
    New NGK wires($45) or a DYI ram intake (say about $30 from autozone using stock tubing and just putting on a 3" cone filter + inlet of 3")?
    I drive like an old man, I don't push my car at all. So I've heard some say my MPG would go down with the RAM intake b/c I'd be "getting on it more" but thats not the case here lol
    90 accord EX automatic F22A4 232,500
    DIY ram intake
    0gauge/4gauge BIG 3
    stock alt rewound to 120amps
    optima orange top 830cca 1030ca
    fully synthetic valvoline "Max Life" 5w30
    Other rides:
    2004 Jeep Liberty v6
    2001 Honda civic ex coupe 1.7 vtec
    I would go ahead w/ the NGK's and run the stock airbox, only cutting off the bottom, that's pretty much a short ram but completely free. It's a great mod, there's a great DIY in the DIY section. Autodinamics on eBay has great NGK plug/wire packages for about $45 (even w/ NGK platinums) but I must warn you, he's quite slow at times w/ getting back to you.
      keep your tires inflated to proper specs, make sure you have a clean air filter no matter which kind, and new wires, cap, plugs would definatly help. also lighten your load. If you have a bunch of junk in your car then that is not helping matters.
        oh Im into hypermiling
        I've got a stripped car
        5w20 oil
        50lbs in all tires
        no system anymore
        nothing in the trunk
        new air filter
        new plugs
        new fuel filter
        drive like old man
        coast down hills
        use cruise control
        just looking for more MPG like everybody
        DIY ram intake
        0gauge/4gauge BIG 3
        Other rides:
          5w20 oil
          50lbs in all tires
          no system anymore
          new air filter
          new plugs
          new fuel filter
          drive like old man
          coast down hills
          use cruise control
          I always find the biggest truck on the highway and kinda follow him so I go in his slipstream and benefit in more MPG. Or just find an escalade to follow, those things are like bricks and take all the aero drag away if your following them. Mythbusters got like 40mpg in a Dodge Magnum by following truck....although really close, but 40mpg none the less.
            Hello,
            Go with the upgraded electrical components. Sounds like you are being very thourough in saving gas, good job. To get much better mileage it sounds like you'll have to get out and push.
            vtechead
              5w20 oil
              50lbs in all tires
              no system anymore
              new air filter
              new plugs
              new fuel filter
              drive like old man
              coast down hills
              use cruise control
              He said he did
              -1991 Honda Accord LX H22a-
                Fuel filter is in the list, check orig. post
                As for electrical upgrade? Not sure what you mean , but I have an optima redtop 0awg big 3 and 130amp alternator. I built this car for sound about 10 years ago, voltage is usually 14.7 to 15V all day LONGGGGGGGGG
                DIY ram intake
                0gauge/4gauge BIG 3
                Other rides:
                  Tires are at 50 PSI per gassavers.org FAQ
                  Ride is harsh, MPG gain is great.
                  DIY ram intake
                  0gauge/4gauge BIG 3
                  Other rides:
                    what kind of mpg numbers are you getting?
                    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
                      i heard air intake gives u some!
                        23-25mpg in city
                        35mpg to 39mpg on highway
                        Im not all that great at hypermiling though, but Im getting better\
                        automatic transmission
                        DIY ram intake
                        0gauge/4gauge BIG 3
                        Other rides:
                          i looked online and it said our cars get 19 or so in city?
                          Lou's Build Thread!
                          http://www.cb7tuner.com/vbb/showthread.php?t=181377
                          "G-Squares Are For Assholes"~PR_CB7
                            i got a ram air intake high flow muffler and no cat convert and hood scoop directly above intake and i romp on the car get 28-30mpg city and 34-36mpg freeway
                            http://www.myspace.com/alliance_nwracing
                            cb7 NOW FOR SALE!!!
                              x2 i saw that show too and if you get within 5 feet of the semi you'll be shaving off the drag and getting more MPG!
                              but if you do that chances are you'll get injured badly lol.
                              Yes my name is Dang, Don't use in vain
                              1992 Honda Accord EX (Coupe/Bordeaux/Auto)
                              1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
                              2008 Honda Accord EXL (Coupe/SanMarino/6spd)
