MY CB DIES a CD DEVELOPS A PROBLEM
    Well guys I guess my cb is dead
    But on another note Im the proud owner od a cd now...
    I bought it about 2 weeks ago..
    Everything was fine till..
    1.) I was driving at mid throttle up an incline, car quits,, no stumble, just dies like I shut it off(no mechanical sounds ie. pops, cracks, snaps, or backfires)
    2.) Once I came to a rest I tried to restart it. Nothing.. It just cranks and cranks with no Firing AT ALL
    3.) Checked fuel at Schrader/bleeder Value.(opened it and turned key forward) plenty of fuel(unsure about psi)
    4.) Checked spark with a spark tester and by hand.. NO SPARK
    5.) Bought Distributor and installed.. STILL NO SPARK
    6.) Pulled the Dizzy and changed distributor to (180*) out.. Still cranks
    BUT NO SPARK
    What has gone on? ECU, MAIN RELAY, TIMING BELT?
    I dont think anything mechanical gave cause I didnt hear it and the lower half still rotates(no seizure)
    All I know is I NEEEEED to get this running soon..
    THNX
    Check the ECU fuse. Check the wiring on the fuel pump too.
    Follow me on IG: @jdm_inspired
    93 'til infinity
      Is it external coil? if you didn't get a new one it would be that.
      wat?
        I probably should have said:
        F22B2 VTEC, Auto..
        The engines getting fuel
        The dizzy is the TD-58-U/ with internal coil..
          My buddy and I had about the same problem as you are having. To me I believe it could be the alt. If your battery is fine and nothing else happened that could have caused this get the altanator checked (my spelling is not that great). If it's not that good luck trying to get your car up and going!
          Save a Driver. Drive a Honda.
            Mine did that. It was the alternator, apparently when it died, it made the voltage go nuts and blew the BATTERY FUSE(80amp), blew the ECU fuse, and some others
            New alternator, all new fuses, problem solved.
            90 accord EX automatic F22A4 232,500
            DIY ram intake
            0gauge/4gauge BIG 3
            stock alt rewound to 120amps
            optima orange top 830cca 1030ca
            fully synthetic valvoline "Max Life" 5w30
            Other rides:
            2004 Jeep Liberty v6
            2001 Honda civic ex coupe 1.7 vtec
              I highly doubt it is the Alt. Im thinking Main relay or ECU..
                problem = timing belt
                  I doubt its the timing belt. Check fuses, and check the iginition coil.
                  1991 Honda Accord EX F22A1
                  Coming Soon... F22B DOHC w H23 Tranny
                  "My phone kicks in a 5000 RPM's"
                    I agree, check the alternator and If you havent already reset the ECU by pulling the fuse for about 30 seconds. And A car is never dead until it has burned to the ground. They can always get heart transplants. Good luck
                    Arcadia Green Crew Member #9
                      That is a nice cb. Sell it to me. j/p
                      THE POWER OF DREAM
                        i'm thinking it's your main relay but i could be wrong
                          Na seriously.. its the timing belt...
                          timing belt turns the cam, cam rotates the dizzy... its gonna cost about 500 to fix.. if it was the alt then it would loose charge and not turn over at all...
                            Timing belt won't cause a no spark condition. The coil fires off of the CkP sensor, which is unaffected by a snapped timing belt, so the coil would not be affected in that regard. Why would you install the dizzy 180 out? Check the wiring inside the distributor, be sure the pin-fit at the ignitor is good, and that the wires are installed at the right locations. (easy to mess that up, believe it or not). Also, make sure the cap & rotor are in good condition, no moisture, etc. Bad main relay could cause a no-start, but not typically a died-while-driving situation.
