more crank pulley trouble
    so a couple friends came n checked out my pulley's condition. and it turns out its very loose. this time i was told, either the woodruff key needs 2 be replaced or i could have spun a bearing. let me make it clear that i first heard the pulley making noise, knocking around while driving. i pulled over and confirmed that the pulley was indeed wobbling around at idle. however, the car still drove that day. after i parked it in my yard however, it would turn over and start, but then die. wether i left it in park, neutral or put it in drive. is this more likely a symptom of a woodruff key or a bearing?
    what? So you park the car, after that you start and it die?
      that was what was happening, yes. it used to turn over n just die. no weird idling or nothing before it dies.
        so what, nobody wanna help diagnose my problem?
