91' Accord Stalls.. Randomly.. Please help me.. :'(
    K i got a transmission put in my car bout a month ago now.. and we just changed the main relay this morning.. it starts now.. thanks for that. But now, it stalls when i have to stop at a light, or in traffic. Do i just need to adjust my idle? cause it doesn't sound funny.. just dies and starts right back up when i turn the key.
    Can anybody help me?
    92' Ex - Needs work, but hey! It runs safely
    91' Lx -Car vs IDIOT.. R.I.P.
    RIP 92' Lx... Car vs Concrete.. Car lost.
    when it dies, check for spark.
      my car does the same thing, its only when its hot though, i can just barely tap the gas pedal and it will bog down real low, most of the time it dies, sometimes it will stay alive, but for the most part, it dies, then i can start it right back up, tap the gas, and it bogs down again and dies :-( but if i keep my foot on the gas it will stay running
        Could be a fuel issue.
        1993 Accord EX
        2011 Subaru STi
          heat causes more resistance in the electrical system, so make sure your ignition system is up to date. another issue i had was at random but my fuel injector resistance box would take a shit when the engine bay got warm.
          i tested it at cold and after it was like 100 degrees outside.
            is it stick shift or auto??if its auto itz prolly a torque converter issue...sounds like it to me....more likely than anyting else
            Lost Motion Inc. Repair and Performance Automotive
              Clean and tighten all battery connections and grounds. That may not be the cause, but it's possible. It's an easy thing to rule out, and an easy fix if it's the issue.
