90 cb7 brakes
    90 cb7 brakes
    is it just me or does everyone have to pump there brakes sometimes.
    i have enough brake fluid, should i bleed my brakes or would that be a waste of time
    F22B Swapped CB7
    ehh, I've got all 4 disc brakes (new pads recently), and I could put everything I had onto that brake pedal, and my tires won't lock up. Pumped or not. And when I hit a bump, while havin' pressure on the brake, the anti-lock system will push the brake right back to me. Shit's dangerous!
    98' Mustang 3V Swap
    11' VW CC R36
      Sounds like the seals in your brake master cylinder are getting old. You shouldn't have to pump your brakes.
      As for you I have no clue what your talking about.
      -1991 Honda Accord LX H22a-
        i can get tht checked
        F22B Swapped CB7
          Turn the car off, press the brake, and if the pedal sinks to the floor you have a bad mastercylinder
          wat?
            im not sure if i have abs or not
            F22B Swapped CB7
              yea it hit the floor but when it came back up it was hard to push back down
              F22B Swapped CB7
                well keep pumping it over and over and over again till it can longer hit the floor. Then, wait a min and try again. If it goes to the floor again then bad master cylinder. or a leak
                  i dont think abs came along till 92...
                  92ex CB7<-SOLD 93ex CB9shiftingshift73C10
                    it must b my master cylinder then
                    F22B Swapped CB7
                      Get it done ASAP. There's a high probability you'll lose your brakes soon enough.
                      1996 Honda Civic LX 2009-2012
                      2012 Kia Optima LX 2012-2013
                        ait thanx
                        F22B Swapped CB7
                          i had to bleed them
