Oil leak from
    Oil leak from
    I changed my oil the yesterday and everything went good.The oil isnt comming from the oil pan or the oil filter. so what should i do?it looks like the oil is comming from the left side of the filter. i keep thinkin maybe i coulda screwed the oil filter on wrong but it screwed on real easy so idk??
    i drive a 91 accord 5spd
    Did it leak oil before or after this oil change. Could be the oil pressure sensor right above you oil filter. They are known the crack and leak.
    -1991 Honda Accord LX H22a-
      it started to leak after the change
        Did you make sure the old gasket came off with the filter and didn't stick to the block.
          Honestly, I JUST had this EXACT problem, and after an oil/oil filter change. Wow.
          http://www.cb7tuner.com/vbb/showthread.php?t=107194
          It tuned out to be my oil pressure switch, which is directly above the oil filter. Read the thread, it's got all the possible points of leak on it.
            Ok i found the problem. i had a dart hole in my oil filter?
            i must have been playin darts one day and the dart fell right in the new box....so i fixed gotta it changed out. now my car is just burnin all smoke in the work bc of all the oil i droped lol.....
            hey thanks guys
