i got an F series dropped in and now i have an engine light. i think it may be the 02 sensor. also on the intake mainifold all the way to the right there are two prong type things. should something be connected to those? i found this pic online and circled the two hoses in red.
inatke mainifold ?
Hey man. Same thing happened to me when I got my new engine swapped. It threw 3 codes, and I just reset the computer. (Take negative terminal off, and take out the Radio fuse in the fuse box under the hood of the car). Codes went away, but...if you do that, then the CEL comes back on, check this link out.
Easy way to let ya know exactly what's wrong. Oh, and after you do the stuff with the comp. reset, might wanna take your car for a spin. My car seems to take awhile for it to find the problem, and pop that Check Engine Light on. After I reset the battery, out of those 3 codes (Speed Sensor, o2 sensor, and EGR valve), the o2 sensor code came back after a few days. Come to find out, it wasn't hooked up. Dumbass mechanics around here.98' Mustang 3V Swap
11' VW CC R36
