More than one insert?
    is there more than one motor mount insert for our cars, or do you really only need the front one to be replaced. cause my front is shot. so i ordered a prothane one, just wondering if thats all i need to fix the vibration or is there more to it, like replacing the other three?
    Thanks!
    1992 Accord EX-R 4 door Cobalt blue on blue 5 speed, friggin love this car.
    Performance mods: AEM short ram intake, Progress rear sway bar, and Apexi WSII cat back, skunk 2 wieghted knob, yeamans short throw. exedy oem style clutch pkg with a F1 racing 12lb flywheel, TASauto braided SS clutch line.
    Sound mods: Hertz space 6 1/2 speakers and tweets with a Audison Srx 2 amp, Focal 11" sub in a Focal ported box, Kenwood D-class amp, Audison cap and a Kenwood KDC891.
    TTT no one?
      how do u know its only your front mount? mine shakes also. waiting for money to buy all 4 stock mounts.
      you'll love my nuts!
        mine use to vibrate. all i did was change the front strut mount. no more vibration but i cheecked all of my mounts .
          Are you sure you have a prothane motor mount insert for the front? I have a prothane motor mount insert for the rear and an energy suspension insert for the front. I wouldn't recomend using them together though as the vibration was unbearable for me atleast.
            I was told mine needed the rear mount, I haven't seen it yet but looked up the part some have a solenoid with it what is that for?
              hahaha...be prepared to fight with that one. I almost took off the intake mani to change the rear mount. It sucked.
              Check out ESP engine mount kits for your CB7!!!
                If your mount is broken, an insert won't fix it. In fact, when you get your insert, the package will say "do not install if the rubber of the mount is damaged".
                The front mount doesn't hold any weight, so that isn't the source of your vibration. If it is, that means the mount is bearing a load in some way, which means something else is wrong. The rear mount is most likely the culprit.
                Adding inserts, or filling the mounts with urethane, will INCREASE vibration.
                  would a feasible solution be just getting a det of esp mounts when i get my clutch redone coming up soon...maybe adding a four link and a strut bar into the mix?
