low beams dont work....
    after going through all my fuses and stuff, making sure everything is good...my low beams stoped working....my high beams and my drls work (their the same bulb...), but my low beams dont...i found the wiring diagram, and i looked everything over....everything crossed out in red are working properly...i also tried using another headlight switch...no go
    im at a loss....i also tried grounding the light and using the power from the source, still nothing, but the bulbs work if i put 12v to them.
    im driving a 92 accord EXR f22a6.
    any ideas?
    i just tried taking a bulb out, running a wire from the r-headlight fuse to the bulb, and used the battery for a ground, and it worked...so i have power at the fuse..so it must be the power line from the fuse box to my low beams......
      nobody has any idea's?
        I slept on your problem and the only thing I can think of is ground you have already covered. You are right it seems to be power to the bulbs and with that in mind the most likely failure point would be the relay. Sorry I can't be more helpful.
        vtechead
          i tried replacing the relay with the one out of my other accord (91 exr, f22a6), which i know works, there is no change....im starting to think that ill just hook up a relay to the headlight fuse, and hook up a wire directly to the bulbs,that way they'll automatically turn on when i turn on the headlights, as well the low beams will stay on when i got my high beams on. cant think of any other way of fixing it *shrugs* if anyone else has any suggestions, im open to them. Thanks anyways vtechead.
            Id say change bul;b if dont wrk change light switch
              the bulbs work as when i put 12v directly to it, it works, i changed the light control fstick from the other one, still doesnt work.
                so i did the mod today, worked great,
                heres how...
                results...
