I just swapd out my skunk 2 lowering springs for some drop zone coil overs i purchased, the car runs nice and smooth but jumps a little when there are bumps, like on a bridge. But then again its slamd rit now, and i have new KYB GR2 shocks, if I raise it a bit, would it minimize the jumping?
Suspension ?
You replaced Skunk2 springs with Dropzone coilovers?
I know the Dropzones are adjustable... but honestly... that's like "upgrading" from a 2002 BMW to a 2007 Kia. Dropzone makes some of the most terrible garbage you could ever put on your car!
The spring rate of those coilovers is probably pretty high. Dropzone makes things cheap... their major concern, their ONLY concern, is a low price to move their products. They show little consideration for comfort, performance, or even safety (I broke a Dropzone camber kit in 2 months).
If you MUST have adjustable coilovers, drop the extra for some Skunk2 ones. The crappy ride you have now is probably the best you're going to get from those things.
Also, you do realize that every time you play with your height you're going to need to get realigned, right? That, or you're going to chew up tires (and with each tire costing as much as an alignment, it's not a wise thing to do!)
[QUOTE=deevergote;1506631]You replaced Skunk2 springs with Dropzone coilovers?
QUOTE]
Same thing I was thinking,..lol. was was your reason for switching to the coilovers in the first place. we learn new things everyday man, don't wory abou t it so much. I am pretty sure you will need an alignment after swithching suspension. I hear gound controls are really good coilover sleeves.
Originally posted by mySICKOcb7 View PostI just swapd out my skunk 2 lowering springs for some drop zone coil overs i purchased, the car runs nice and smooth but jumps a little when there are bumps, like on a bridge. But then again its slamd rit now, and i have new KYB GR2 shocks, if I raise it a bit, would it minimize the jumping?
Originally posted by F22HB View PostWhat will minimize the "jumping" would be a stiffer damper. On our cars for the most part, the spring is there to soften the compression of the suspension and the damper is to soften the expansion. When you have stiff springs and soft struts the spring will have a tendancy to overpower the strut and you get a bouncy car as a result. Thats why coilovers are typicaly paired with adjustable dampers...
