Hey, I finished my H22a swap yesterday, I started the car with no problems but the idle is low at first with no check engine light but 5-10 seconds afterwards it starts to idle high and the check engine light comes on. But thats not all, there seems to be a over heating problem. The fan do not come while the engine is running, it comes on when I turn off the car, another puzzling thing is that the temp guage in the car reads normal. Can any one shed some light on this for me?
Need Help....H22a Swap is completed.
how do you know that the car is overheating if the temp gauge is reading normal? Also, what check engine code is it throwing? It would help us solve you problem if you filled us in on all the details. Its probably almost guarenteed that once you pull your check engine code.....You'll be able to solve your problem(s)
Originally posted by CATunner View PostWell, you see the engines starts to smoke and you notice the idle change. how can I find out what code do the engine is throwing?
Did you bleed your cooling system?
Also, the smoke is somewhat normal, especially if you spilled any oil on the engine at any point during the swap. It should all burn off after a little while.1992 Prelude S w/swapped H22A
