hi all i am new here and New To Honda's as well, this is my first post... think i am putting this in the right place.
i am wondering if anyone can help me.
i own a honda accord 97 V tec 4 door.
and i am looking at a list of parts / mods. i dont think you guys deal with my car but im not sure what it comes under, so i can understand if you cant help me. if you cant would someone be able to point me in the right direction.
anyway. i have read most of the stickies posted, some where very helpful, but i still have a couple of questions for car modifying.
as i said in the title i want to set my ride up for circuit racing.
i just dont know whats better the f22b1 that came stock, or swapping to a h22 -k24.
the current motor is stock except for the sports exhaust, and i have sleeved the cat converter. tuned and dynoed. currently im putting out 176 kW @ fw.
i dont know weather to continue with modifying the f22b1 or swap.
i have a list of parts below, that i would be buying to modify the motor, the list of parts are listed for the f22b1 only, but i would be doing the same mods for the h22 - k24 alike.
after looking at the list of parts what would give me more hp/ kW's
i want to get as muh power out of the motor as humanly possible
$ is not a problem
i am also stuck with cam shaft - oil pan - stocker kit - timing belt -
Under drive pulley - brakes - and clutch.... these parts are listed in the parts list but i am need of some help
and if there is anything the i have over looked please suggest it as all the help i can get the better, as i can only go by what i have read and heard and my willing to learn more is high...
thank you for any and all help
I STILL NEED THE CAR ROAD LEGAL as i will be using it for time to time
regards stix
and list of parts below:
Category: Part Number:
Air intake:
AEM V2 cold air intake AEM-246008C
Blow off valve:
Turbonetics Godzilla Bypass blow off valve TN-10765
Cam shaft:
NOT SURE WHAT CAMS I CAN GET NOT SURE
If you can find out for me that would be great thank you
Cam sprockets:
Venom Fang Cam Gear set VNM-C21-127R
Cooling system:
Fluidyne Direct fit Radiator FHP-1193ACC
Fluidyne Fan X2 ?? but part num is MMFAN-10-1
Distributor kit:
Crane Cams Fireball kit (it says it for EX,ED accord) CC-730-0694-01
Engine oil: what do you think would be better???
ENEOS 0W-50W, 6 Quart Synthetic Oil ENEOS-API-SM-0w-50
GReddy GR Synthetic Oil (3 different grades) GR-1,GR-2,GR-3. GREGR35w30
Fuel system:
AEM adjustable fuel pressure regulator AEM25304
AEM high pro fuel filter ??????????????
AEM high volume fuel filter AEM25200
AEM high volume fuel rails AEM25106
WALBRO 255 LPH high volume Pump WALGSS342-400-826
Ignition system:
NOT SURE WHAT I NEED BUT LOOKED UP SOME BRANDS
IF YOU CAN THINK OF OTHERS AND THE PARTS PLEASE ADD,
Accel
MSI
Oil catch tank:
GReddy oil catcher kit (might not match car) GRE12054601
GReddy universal oil catch tank GRY-13500515
Oil cooler:
GReddy 10 row oil cooler GRY-12051510-1
Golden Eagle V-Tec Conversion kit GVC100 ??
Oil pans:
NOT SURE WITH PART PLEASE LOOK AT
Turbo kit:
Drag Gen 4 turbo kit Honda accord DRAG-DT480AS2
Spark plugs: PLEASE LOOK AT OTHERS AS WELL
Greddy ????????????
Spoon Sports spark plugs Honda accord SPN-98079-16B-027
Stroker kit:
NOT SURE WITH THIS PART
Timing belt:
NOT SURE BUT THINKING ALONG THE LINES OF (brand only)
Gates blue belt ????????????
Under drive pulley Notes: do I need to buy to non under drive as well as the under drive Crank note one is a tuner and the other ultra?
AEM Tru-Power pulley system AEM237018
Unorthodox tuner billet Crank non under drive UNX220610412
Unorthodox ultra billet Power Steering UNX010640002
Unorthodox ultra billet Alternator pulley UNX010630402
Unorthodox ultra - S billet Crank under drive UNX020610402
Unorthodox Racing ultra UN-0406004-01-R
I also found a Unorthodox ultra - SS billet pulley set. Polished - under drive includes Crank, Power Steering and Alternator pulley UNX040600402
If I buy the set do I need to buy any other pulleys as well??
Cams: Please check that all cams fit the V-Tec
AEM Tru-Time adjustable cam gear AEM23803
Wire set:
NKG 7mm Spark Plug Set NGK-HE73
Ecu:
AEM plug and play engine management system AEM-30-1010
AEM plug and play programmable Ems with Uego AEM301060U
Boost:
NOT SURE WHAT THE DIFFERENCE IS BETWEEN AFC and AVC
A’PEX V-Tec AFC digital Controller ?????????
A’PEX boost controller AVC-R Controller ?????????
Suspension notes: Im also after a top tie or top sway bar, I cant find one!
TEIN pillow pall upper strut mounts front TEIPRH38-31S70
TEIN pillow pall upper strut mounts rear TEIPRH39-31P90
TEIN type CS coil over system TEIDSH38-R1SS3
DC sports billet rear lower tie bar DSHTB3007
Brakes notes: NOT SURE what I can get, I want the front and rear to be the same, Type and brand for front and rear. The ones I have not sure if I can get them for both as I cant find that rear rotor same as the front! please check this as braking plays a big part. Thank you.
I need racing pads and rotors for front and rear.
Brake PADS FRONT: Other bands listed below under part. Not sure if any brake items are for the accord V - Tec, there said they fit accord 97 model.
EBC yellow stuff ultimate race pad EBDP4812/2R
Brake ROTORS FRONT:
EBC slotted & drilled sport rotor kit EBCGD561
Brake PADS REAR:
EBC yellow stuff ultimate race pad EBCDP41193R
Brake ROTORS REAR:
CANT FIND REAR ROTOR SAME AS FRONT!!!
Also other brands are: *needed for racing.
BREMBO
DBA 4000 SERIES
EBC - will look at any other brands if you think they will hold the task!
1 Clutch Ceramic:
Unorthodox ultra G sport pro UNX070630414
2 Clutch Feramic:
Unorthodox ultra G race pro UNX070640414
3 Clutch Kevlar:
Unorthodox ultra G street mod UNX070620410
Flywheel:
Unorthodox ultra aluminum flywheel UNX06010200
Drive train notes:
Trying to find a short shift kit… I know I may need a different gear box all together. I have no clue here though. If I need a new transmission box I want a 5 or 6 speed box, in a normal array not a straight line box.
Exhaust system notes:
Not sure with pipe. I already have part of the exhaust system not sure what it is though as it came with the car when bought it. If you need to know what it is I can find out for you.
DC sports ceramic race header 4-2-1 DCSAHR6516
thank you for any and all help once again
regards stix
$ is not a problem
regards stix
Air intake:
Blow off valve:
Cam shaft:
Cam sprockets:
Cooling system:
Distributor kit:
Fuel system:
Ignition system:
Accel
MSI
Oil catch tank:
Oil cooler:
Oil pans:
Turbo kit:
Greddy ????????????
Stroker kit:
Timing belt:
Wire set:
Ecu:
Boost:
Brake ROTORS FRONT:
Brake PADS REAR:
Brake ROTORS REAR:
BREMBO
DBA 4000 SERIES
1 Clutch Ceramic:
2 Clutch Feramic:
3 Clutch Kevlar:
Flywheel:
Drive train notes:
regards stix
