Im doing my 272 cam swap in 2 weeks and while everything is apart what parts should i replace? the timing belt was replaced at 90,000 miles and their is now 138,000 so i should be good with that, but is their anything else i should do?? thanks alot!!
What parts should i replace?
http://www.cb7tuner.com/vbb/showthread.php?t=91030 <--MY RIDE!
http://www.cb7tuner.com/vbb/showthread.php?t=140230 <--MY ongoing ENGINE BUILD!..Tags: None
valve seals? i thought you had to pull the head to do that?
Originally posted by motobmx105 View Postvalve seals? i thought you had to pull the head to do that?
yeah im pretty sure their not leaking, im not burning oil, well just the normal amount that a 17 year old car would but i change my oil every 3000 miles so i think ill hold off on doing the valve seals, but is their anyhting else i should do?
