camber kit
    camber kit
    Ok I'm really pissed off. Since my car is lowered I got negative camber. 2 front tires popped on me and I got some nice falken tires for 120$ a pair. This was about 1month ago. I notice 2day that the insides are already worn down 2 bare metal. I'm driving to new york soon and I can't afford to keep buying tires.
    What are some good and cheap camber kits I can use? if any1 can link me I'd appreciate it.
    alone in this game . ::My Ride My Way::
    I really doubt camber did that. Toe is what eats tires, camber is just uneven wear.
    wat?
      look on ebay for an INGALLS or SPC front camber kit! i don't think cheap kits are worth the pain.
      i ordered a cheap one and the front camber kit didn't fit...
      Be Clean
        honestly if you want a cheap camber kit then get one off ebay there like 50 bucks shipped but in my opinion i would get a good one cause i use to have ebay ones and in the end it broke would bang against my A arm ingalls and SPC are the good name brands
        CLICK ON SIG FOR MEMBERS RIDE
        "2SIIC"
        Authentic Jerseys for sale
        http://www.cb7tuner.com/vbb/showthread.php?t=188314
          YOu need an alighnment (Sp?). My car had a 3" drop for about 6 months, and i went through 6 tires on the fromt alone. I alighned it myself with the old-school string method when i put rims on it. So far so good...
            I'm pretty sure its camber because the only part that's down to the metal is the inside of the tire.
            How hard is it 2 install these yourself?
              Im tellin you man, befor i even lowered my car, the only part of the tire to wear out was the inside. All older accords ive seen do that.
              Your right though, a camber kit will help, but then your tires are still gonna wear out in 2 months if you dont get an alignment.
                it depends on what camber kit you decide to get there are two different types of camber kits a ball joint and a anchor bold in my opinon the anchor bolt is the easiest since you just remove the old OEM ones and replaces it with the new ones theb all joint one requires you to remove the ball joint that located on the top of the control arm where it connects to the knuckle theres a thread about this look in the suspension section and youll find it there along with a DIY on installation
                "2SIIC"
                  toe, toe, toe!
                    Originally posted by wed3k
                    toe, toe, toe!
                    X2, X2, X2!
                    wat?
                      http://info.rockauto.com/BeckArnley/...ml?1014420.jpg
                      Will these work? They're at a good price. Plus I found a 50% off coupon for an alignment from tire kingdom
                        Get an alignment not camber kit.
                        The one TAS has I like better.
                        wat?
                          Well these are only $83 . And shouldn't I get a camber kit then an alignment?
                          Or would an alignment really help me keep my tires longer than 1 month.
                            his members ride pics look like hes to low for the alignment to help i mean it would possibly fix it a bit but it wont be 100% the camber kit you picked looks ok just remember you get what you pay for
                            "2SIIC"
                              I'm looking for a camber kit in the $100-150 price range. I checked ebay and the ingalls cost like $260. Any other brands that are in my budget?
