ignition problems
    ignition problems
    i was wondering if you guys ever had ignition problems with your CB7's. About a year ago, I brought my CB into the dealership b/c supposedly, they key hole (ignition switch) on the steering column was messed up. Since then, every once and a while, my CB wouldn't start for a while and even if it does, it would die out, like stall making me have to rev the engine to keep it alive. Do you guys have any ideas of whats up?? Any suggestions on how to solve it and how much it'd cost??
    THank you guys
    it's all about the t34m
    Main relay?
    NEW PSN
    H22wagon
    New project. 95 EG HB H22
    RIP
      main relay not kicking on the fuel pump
      miss my turbo cb7
        If you can rev to keep the engine alive, I doubt it's a problem with the ignition switch. It may be time for a tune-up. I would check the condition of the distributor cap and rotor. Worn ignition components can also cause a hard-startup condition as well as a bad main relay.
        "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
          x2
          and then if it persists see if the work the dealership is under warranty still and take it back.
            thanks you guys but....can u explain what the "main relay" is exactly?
