Automatic, D4, Green sport light turns ON !! HELP
    Swap done, but when im put the shifter in D4, the green sport light turns on. Please help me !!!
    Accord M0DiFi3D From Norway
    Visit Website: http://www.garaget.org/?car=63883
    What swap are you talking about? And isn't that light supposed to turn on? More details, please....
    "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
      Green sport D4?
        You just swapped a H22A in right? (at least in one of your last posts you were talking about it. )
        First off, check to see if the "sport" button on the side if the shifter was pressed.
        Usually the "S" light will blink if you are having tranny issues, but yours isn't blinking, it just stays solid correct?
        3 CB's gone....
        1 WK Overland....
        Still miss the CB though......maybe one day.
          Yes ive swapped the h22a jdm with auto tranny.
          When i tested it yesterday, i placed the shifter in D4, and hit the pedal. The gearbox wouldnt shift at all. The green "Sport" light stays solid on.. About 10 min later, this light blinks. This happends just in D4.
          When i shift manually with this shifter, the light turns off, but the gearbox isnt working in D3 either.
          I need to shift manually.
          I bought new gearbox, with a new engine as well:P because the old tranny was broken, and this new prelude tranny seems quite the same..
          Please help me.. Spend lots of hours and cash on this..
            I don't hink the prelude tranny's came with a "sport" button like on our cars. That might be one of the issues. Did you try jumping the connector (like checking for a CEL) to see if it gives you anything?
            Also, if you are using a lude tranny, are you also using the Lude' TCU?
            3 CB's gone....
            1 WK Overland....
              You have a 90-91 cb7? Which TCU did you use. I don't think you can mix and match, which I am guessing is what you did....
                Im using the prelude tcu which followed the h22 engine as well...
                Using a prelude tranny, with prelude TCU. Everything should be fine il guess.. but no.. It woudlnt shift.
                  Did you check to see if there are any TCU codes?
                  3 CB's gone....
                  1 WK Overland....
                    yeah the green sport lights blinks, giving me 2 different codes.
                    Code 9 and 15.
                    9 Short blinks, and 1 long with 5 short.
                    What is the problem?
                      nice to know, my S light links all the time d4 d3 2 & 1... but i dont sweat it for now cuz i will be getting rid of that tranny soon. bump cuz i would still like to know why it blink all the time!
                        Code 9 and 15.
                        TCU CODE LIST:
                        1-Lock-up solenoid 'A' circuit open or shorted.
                        2-Lock-up solenoid 'B' circuit open or shorted.
                        3-Throttle Position Sensor circuit open or shorted.
                        4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
                        5-Shift Lever Position Switch circuit shorted.
                        6-Shift Lever Position Switch circuit open.
                        7-Shift Solenoid 'A' circuit open or shorted.
                        8-Shift Solenoid 'B' circuit open or shorted.
                        9-Counter shaft or transmission speed pulse generator open or shorted.
                        10-Coolant Temperature Sensor open or shorted.
                        11-Engine RPM (Ignition coil signal) open or shorted.
                        12-(No code 12 used)
                        13-Main shaft speed pulse generator open or shorted.
                        14-Linear (line pressure control) solenoid open or shorted.
                        15-Kick down switch circuit shorted.
                        Taken from: http://www.cb7tuner.com/vbb/showthread.php?t=2861
                        3 CB's gone....
                        1 WK Overland....
                          ok thanks=)
                          Does anybody know how to fix these problems as well? Please?
