Motor mount inserts?
    motor mount inserts on ebay
    My mechanic showed me my rubber was cracked on one of my motor mounts. Does the mount need to be removed to install these inserts? I think this is the best fix especially because hes charging me big money for new mounts. The motor does vibrate my dash with smooth idle.
    RoaR MRT
    if you didnt remove the mount, how would you be able to slip the inserts into the mount? the bolt goes through the bushing.
      x2, but the inserts actually work. if you have a problem will busting motor mounts that this will definitely take care of that.
        and btw, i believe those are for 94-97 accords. i don see any applications for the 90-93 unfortunately.
          Read the package.
          2003 Maxima SE Titanium Edition
          1993 Suzuki GSX1100F 136bhp
            Originally posted by SteveB
            Read the package.
            yea actually the package doesnt say anything about the year or make of the vehicle. it just has the part number which is the wrong part number for 90-93's.
            it's actually 16.1107 my bad.
            btw, here's a cheaper source. http://www.sportcompactstore.com/spo...Product=539979
              The inserts won't fix a broken mount. Replace the mounts, or fill them. Filling them will make for more vibration inside the car, especially at idle (and definitely when the AC is on), but it will also result in less mount flex. I have filled mounts, and I like them.
                after a while you guys with the filled mounts probably don't even notice the vibration anymore do you?
                  It's not as noticeable as it was, that's for sure. They may have "broken in" a bit as well. It's not something you'd want to do if you weren't performance minded... but if you have a loud exhaust and a stiff suspension, it's no worse in terms of discomfort than those things.
                    that's good because i'm going to be using the ESP mounts.
