RAM Intake
    RAM Intake
    Hey guys
    Whats the difference between a shorter RAM and the standard one? Pros and Cons?
    (This is my first time tuning a car, and this forum is the best way for me to learn about this stuff.)
    short ram is not a cold air intake,cold air unit piping will continue into fender. i recomend the full cold air,both short and full will give noticable hp change from stock
    "Cracker's crumble Honkies rumble"
      Short ram
      Pro: better air flow, Sounds good, Quick replacement, cheap, maybe 1-2 hp
      Cons: Still sucks hot air in the engine bay.
      Cold air:
      Pro:Better air flow, Sounds good, Recieves outside air temps instead of engine bay temps, maybe 3-5hp
      Cons: Have to be more careful about water puddles cuz if you suck up water, say bye bye to ur motor, Little bit more time consuming to install, Usually a bit more expensive.
      The pros and cons of both arent huge but those are really the only things that come to mind. You wont get a huge increase from either of them unless your motor is built. Well you wont ever get a HUGE increase from either but the butt dyno will notice. But the Cold Air Intake is preferred by most and it is considered a better performance upgrade than the short ram.
        Originally posted by chrischhorn
        Short ram
        Cold air:
        Water puddles? I've heard mention of a bypass valve, is that necessary?
          bypass valve is a must
          UNDERGROUND SOCIETY
          NEW COUPE MEMBERS RIDE THREAD COMMING SOON
            Thanks. I've been reading on this since I posted and I found that some people frown upon valves as they make your engine lose power. Is that true?
              ive never heard of the losing power thing but then again i never did run a cold air intake.....i went from short ram to boosted
                the main purpose of the bypass valve is to stop hydro lock, you will not lose/gain hp from installing one. if you drive in the rain often then GET ONE!!!! but if your car doesnt see rain then dont worry about it. i ran a short ram for 2 years before switching to the full cai, i have noticed alot of gains. im chirping tires in a auto for christ sake
                UNDERGROUND SOCIETY
                  HAHAH Sweet!!! Thanks everyone!! Guess thats my route then. CAI with a bypassvalve. *whew*
                  You guys rock. Helping out noobs and all.
                    if you dont wanna spend lots of money, get a cai off of ebay an put a better filter on it
                    UNDERGROUND SOCIETY
                      Whats a better filter brand?
                        K&N thats what i got
                        even the filters from your local autozone/advance is better
                        UNDERGROUND SOCIETY
                          You'll loose a lot more power when you suck up water and hydrolock.
                          1992 Prelude S w/swapped H22A
                            you will not have any power if you hydrolock
                            UNDERGROUND SOCIETY
                              Link
                              so something like this? And just replace the filter? (and add the valve?)
