My ECU only reads code 43 when the car is at regular temperature, but my fuel pump comes on like normal. If the fuel pump is faulty, shouldnt code 43 come up as soon as i turn the car on?
Code 43
Originally posted by Juicy_JCode 43 is the Fuel supply System. I reset the ecu and still it only comes up when the car is warm.
How old is your filter?2003 Maxima SE Titanium Edition
1993 Suzuki GSX1100F 136bhp
Whats cool is most of the time this code can be solved via changing the o2 sensor. Why? I dont know lol.
From ALLDATA: Check engine light indicates Code 43: Most likely a problem with the oxygen (O2) sensor circuit or a problem in the fuel supply system.
My opinion: If the CEL comes up only when the engine is warm, it is very likely that there is a problem with the oxygen sensor (circuit) since the ECU will enter closed loop mode after a preset period of time. At that point, it will poll the oxygen sensor, and if the data from the oxygen sensor is erratic or unavailable, the ECU may throw code 43.
"The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
Originally posted by IAmTheNightFrom ALLDATA: Check engine light indicates Code 43: Most likely a problem with the oxygen (O2) sensor circuit or a problem in the fuel supply system.
