Grrr....
    Grrr....
    Alright... i've taken out this H22 like 4 times now with a buddy of mine (92accordbl) and we just got it back in and now it won't start.
    We have plugged everything in, checked all the grounds, checked for ecu code (none), checked the main relay, checked the fuses and nothing...
    When you attempt to start the car, no gas comes out the fuel line...
    WHAT IS MY PROBLEM?!
    -Lance- (Formally known as H0ndaspyd3rLM)
    Originally posted by H22Artman
    if he still disagrees. well...... buy him a pink sweater and tell him to go buy some curtains.
    I posted a nude photo of myself on cd5tuner.com... it broke the site.
    Bought from: lo_dit, 924dr, Fatman88, 91project, noobcake, loud92cb7
    ٩(•̮̮̃•̃)۶
    does your main relay click at all...if not replace it...no fuel no start buddy...also check for spark...but do it safely with out starting fires...im not being a dick or anything...let us know
    OLD
      checked the main relay...even took his out and put it in my car and my car starts, it ran before....the CEL isnt even kicking on either so there is no chance for pulling codes.
      Members Ride / Facebook
        check to see if either the ecu fuse in the underhood fuse box and the one in the drivers kick panel are ok? just a thought?
        some cars have wings cuz they look cool.
        some cars have wings cuz they increase efficiency.
        some cars have wings to keep them from taking flight.
        f1 fan
          Can you hear the pump whirring? Which fuel line? Before orafter the filter?
            I just tried again and i can't hear the fuel pump whirring...
            Let me explain the before...
            One of my injectors popped out of the hole where it was supposed to sit so i had to semi-put it back in and drive home with it like that. I wasted 1/4 a tank of gas. After that, the line that connects to the fuel pressure regulator, poured gas while i wasn't at home.
            Does that help?
            ٩(•̮̮̃•̃)۶
              I also had problems starting my H22A when I swapped it, and I didnt hear the fuel pump either...
              Bought a new main relay, but it still didnt help...
              Then I tried to jump the contacts for the fuel pump on the main relay, and it started!
              Take away the jumper and it stopped...
              This was only a problem with the p13 ECU.
              My members rides thread
                Haha, i have a p13...
                BUT...
                When the car is off, about 1 minute and 30 seconds later, i hear the whine of the pump...
                I'm thinking its a ground problem somewhere inbetween the relay (Because it has power (just checked)) and the pump (because i heard it)
                Gonna check soon...
                ٩(•̮̮̃•̃)۶
                  BUT...
                  Gonna check soon...
                  ********************************UPDATE************ *******************
                  She is now getting fuel...
                  Going to check for spark next.
                  ٩(•̮̮̃•̃)۶
                    how did she get fuel all of a sudden?
                    *Needs*
                    -New shocks
                    -Struts
                    -Drop
                    -Cleaning
                    -New Tires/Wheels
                    -New Window Tint
                    -Alot more lovin'
                      I don't know...
                      She has fuel, i can hear the pump.
                      The relay now makes lots of spark-like sounds when its in the acc position
                      She almost turned over... 2 times...
                      Still trying...
                      ٩(•̮̮̃•̃)۶
                        I don't know...
                        Still trying...
                        Now the check engine VERY faintly comes on. It only comes on when the main relay makes the spark like noise so it flashes on and off as the main relay makes the noise...
                        ٩(•̮̮̃•̃)۶
                          i say check all the fuses or the little brown and black boxes under the steering column ( forgot what they're called.) my old teggy had the same problem and we switched one of them out and it started right up
                          Not So Slow Fow Dow
                            I have a question, how many grounds are there?
                            I have 4 right now.
                            1. The starter ground.
                            2. The ground under the starter. (chassis)
                            3. The ground beside the battery. (chassis)
                            4. Valve cover ground. (chassis)
                            ٩(•̮̮̃•̃)۶
                              Now the main relay is making a slight hum sound...
                              ٩(•̮̮̃•̃)۶
