I just bought an h22 tranny for my 92 ex with an h22a4, when i put it in there was no 1st gear. I have stock linkage, so would i need to swap to h22 linkage???
H22 Linkage???
Your Accord shift linkage will do fine (I assume we're talking about a manual transmission). If first gear is inoperable, that is a problem with the transmission. Where'd you get it?
"The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
Originally posted by DiehlioI just bought an h22 tranny for my 92 ex with an h22a4, when i put it in there was no 1st gear. I have stock linkage, so would i need to swap to h22 linkage???
so when you say there was no first gear....you could put the shifter where first gear SHOULD be, and you were still in neutral? or you couldn't physically get the shifter to the first gear position?
Sounds like an auto? If you cant find first gear with a manual trans you either have a broke linkage, connected it wrong *dunno how that would happen*, something came loose or not bolted on. But first of al auto or manual.
My fault its a five speed...I actually had a friend that works at a Honda shop put it in for me and he said the shifter was where it should be and it was just like neutral. I bought it from a guy locally, i WILL get my money back. Thanks for the help. O and i have another question about doing an A/C delete on my H22, what size belt will i need for this??Last edited by Diehlio; 05-24-2008, 03:10 AM.
