Clutch Fluid Leak
    Clutch Fluid Leak
    So it turns out my clutch fluid system is leaking. It looks like it's coming from the piece that you bleed the clutch line out of. I believe this is the slave cylinder? How easy is it to replace those and how much do they cost usually? Thanks
    theyre really easy to replace. there should be a diy in the diy section. they cost around 20 to 30 bucks.
    alone in this game . ::My Ride My Way::
      two 12 mm bolts and that hydraulic line going into it... just remove and reinstall those when you take off the old one and put on the new one.. shouldn't take any longer then 20 minutes, then make sure you bleed it.
