crank but no start
    crank but no start
    hey fello cb7 owners! once again i need your help. i was driving in my cb and i apporoch a 4 way stop . so made the stop shift back to first gear and i took off and my car dies it will crank but wont start. ive checked feul pump and fuel filter so i know its not a fuel problem btw there is fuel in the car. since i have msd ignition i was wonder if it can be the ignition coil . parts that been checked or changed, battery, main relay,distributor, fuel components, time belt and timing is on perfect. please help missing my car
    thanks
    same thing happened to me but later on after over ten trys, it just started back up like nothin happened...
    don't take life so seriously, no one gets out alive anyways...
      thanks
      i've heard some msd ignitons have a tendency to overheat. i had a problem like that with my h22 but it turned out to be the main relay. good luck.
        Definitely start with the main relay. There's a sticky on this in the DIY section. I just did mine yesterday. It never died while driving, but periodically wouldn't start when hot.
        http://www.cardomain.com/ride/2418752
