This winter I changed my front brakes with new rotors, pads, etc. because I was getting a nasty vibe in the steering wheel when braking hard getting off the highway. The vibe never really completely went away - and now it seems to be getting worse by the day. The car drives pretty well and I really only notice something when I hit the brakes hard. I jacked it up the other day and there is a little horizontal play in the driver's side wheel. The ball joints seem tight - so would this be a tie rod issue?
Another vibe question
Vibes...
Vibes are always fun! kidding. i work with brakes alot and it does sound like you had some rotor issues because of braking then getting a vibe in steering wheel but that comes with owning a car lol. resurfacing the rotors usually takes the 'warpage' out of the rotors and causes them to have a tolerable runout so u dont get that nasty vibe when braking.
however having bad front end parts: tie rod ends [inner and outter], ball joints [upper and lower], sway bar links, caster rod bushings, ect ect can all cause vibrations but not usually when braking. CV axles can also cause a bad vibe but thats normally upon loaded acceleration and its usually the inboard joint thats going bad when that happens. when you get the clicking thats usually the outboard joint going bad.
