NO GRAB\\help// THROW OUT BEARING? SLAVE?
    I just got my motor back together and in and the tranny back in and all that it runs fine and all.
    problem...
    i bled the clutch and it wouldnt seem to get really tight it feels loose still, like more loose than normal it wasnt like this before the swap.
    when you depress the clutch pedal when the car is off it feels normal but is loose not tight
    while the car is running if you depress the clutch pedal it feels grindy/ grainy feeling.
    Now for the main problem when i let the clutch out its not engaging it feels like if you pop the clutch out when its in gear it will kill it but it wont jerk forward really hard like it should. when i tried to drive it it feels like the clutch is slipping and i can smell the clutch burning up after like 2 minutes of driving it.
    anybody have any ideas/ suggestions could my throw out bearing not be line up right... could it be my slave i know the one i have leaks. and other comments/ suggestions welcome
    TIA
    problem...
    TIA
    I thinkin slave may be the is just not lettin it keep pressure?
    Freedom Is Not Free
    U.S Army 02/08 Medically Discharged
      anyother suggestions im gonna replace the slave today and see what happens with that.
        bump
          im having a similar issue. i bled the clutch like 3 times already and its so damm soft. i have a stage 3 xtd. and the pedal isnt hard or tight, its like soft. sometimes it wont engage in reverse.
          miss my turbo cb7
            does your clutch start burning soon after trying to drive it.
