New problem...
    New problem...
    I'm recieveing 3 codes...
    6 ECT - water temperature sensor
    10 IAT - intake air temperature sensor
    21 VTEC spool solenoid valve
    -Lance- (Formally known as H0ndaspyd3rLM)
    Originally posted by H22Artman
    if he still disagrees. well...... buy him a pink sweater and tell him to go buy some curtains.
    I posted a nude photo of myself on cd5tuner.com... it broke the site.
    Bought from: lo_dit, 924dr, Fatman88, 91project, noobcake, loud92cb7
    ٩(•̮̮̃•̃)۶
    stop blowing shit up
    Members Ride / Facebook
      CODE 6 – Coolant Temperature.
      Coolant Temperature – a resistor which sends signals in accordance with change in temperature.
      What to do: Remove and replace the sensor with a new part. To remove the sensor , unlock the locking tab then unplug the green electrical connector located under the distributor and carefully unscrew the sensor. Be advised that coolant will leak out during this process and must install the new one ASAP. Before installing the new part , it is recommended to wrap the new sensor with Teflon tape to prevent leakage. Plug back the electrical connector and reset the ECU.
      CODE 10 – Intake Air Temperature Sensor
      Intake Air Temperature Sensor – monitors air temperature getting inside the intake manifold.
      What to do: Replace the IAT sensor. It is located on the intake manifold. To remove the IAT sensor you must unplug the electrical connector and remove the screws that hold the sensor to the intake manifold. Remove the IAT sensor and replace with a new one. Installation is reverse of removal. It is also recommended to reset the ECU.
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
