Speedometer took a crap on me
    yesterday i removed the dash to take change a bulb and i thought everything was fine but now i noticed my speedometer doesnt work. what can this be? im pretty sure evrything was connected right.
    alone in this game . ::My Ride My Way::
    anyone?!!?
      your speed senor could have went bad or something in the speedometer cluster is binded
        i doubt the speed sensor went bad because it was working b4 i put it back in.. the harness on top of the cluster is the one that controls the speed sensor
          have you actually looked at the speed sensor on the transmission ? or just the harness because thats the only thing i can think of that would cause the speedometer not to work or maybe your cluster went bad when you took it out check all your fuses also, other than that i wouldn't know what els could be causing your problem
            now the long task of taking out my dash AGAIN! and checking the harness. i was thinking, since im already taking out the dash i might as well make use of it, so is there anywhere i can get a brand new cluster? like from a dealer or some website?
              hmm how about redisconnecting battery and connect again to reset ecu.
              *Needs*
              -New shocks
              -Struts
              -Drop
              -Cleaning
              -New Tires/Wheels
              -New Window Tint
              -Alot more lovin'
                ill try that. im willing to try out any option until i resort to having to take out the dash again
                  jusz reset the ecu and nothing.. now all i hv to do is take out the dash and chek if the harness is put in
