ok so on my way to school this morning i stopped to get gas, the car seemed fine when i was on my way to the gas station but after i put in 10 bucks of gas (gulf station) of 87 which i always used my tranny seemed to be stuck in 2nd gear when its in d4 d3 and 2nd. also the sport light is on in my gauge cluster even when the button has it turned off. 1st gear works neutral rev and park all work but when its in either d4 d3 or second im pretty sure it doesent switch out of second gear. can someone tell me what i should do??? its auto by the wayy
tranny problems help!!!
you don't need one, just a paperclip.
follow the directions here.
http://techauto.awardspace.com/transmission.html
Originally posted by 91projectso basically i need a new tcu
right?
If the S is blinking that doesn't stand for sport lol.
Heres the location of the blue wire thing.
http://i50.photobucket.com/albums/f3...0/DSCN0208.jpg
http://i50.photobucket.com/albums/f3...0/DSCN0209.jpg
http://i50.photobucket.com/albums/f3...0/DSCN0211.jpg
http://i50.photobucket.com/albums/f3...0/DSCN0212.jpg
plug in a paper clip 2 both of the ends and turn your car on half way, and start counting the blinks.
TCU Codes:
CODE LIST:
1-Lock-up solenoid 'A' circuit open or shorted.
2-Lock-up solenoid 'B' circuit open or shorted.
3-Throttle Position Sensor circuit open or shorted.
4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
5-Shift Lever Position Switch circuit shorted.
6-Shift Lever Position Switch circuit open.
7-Shift Solenoid 'A' circuit open or shorted.
8-Shift Solenoid 'B' circuit open or shorted.
9-Counter shaft or transmission speed pulse generator open or shorted.
10-Coolant Temperature Sensor open or shorted.
11-Engine RPM (Ignition coil signal) open or shorted.
12-(No code 12 used)
13-Main shaft speed pulse generator open or shorted.
14-Linear (line pressure control) solenoid open or shorted.
15-Kick down switch circuit shorted.
