adjustable cam gear
    adjustable cam gear
    i was searching threw tas auto and i came upon these adjustable cam gears. can anyone explain to me what they do and are they really worth it? and also if they will fit on my f22a6. thanks in advance
    alone in this game . ::My Ride My Way::
    some really good brand cam gears are AEM and SKUNK2. i dont know too much about them, i think that they can be adjusted to control open length of the valves for better perfomance. with the correct adjustment, increase in HP for sure.
      thanks. would this b a good item to buy? or u think im better off just leaving it alone and saving for something else.
        Adjustable cam gears allow you to adjust the timing at the cam. You can either advance it or retard it a certain number of degrees.
        3 CB's gone....
        1 WK Overland....
        Still miss the CB though......maybe one day.
          wasn't there a problem with the big name brand ones where the bolts that hold the gear would back out? i think the company suggested people use loctite so that it doesn't happen.
