Cruise control issue.
    To all that read this.
    I have done most of my research in the last couple of years of how to fix this problem. I would like to get my cruise control working again. I dropped in an H24A 95mm stroke and 89mm bore motor in my 92 Accord EX. I swapped it from Auto to 5 spd, totally a more interesting car to drive.
    I have missed the cruise control on my wheel and I am needing it because I have such a heavy foot with all that power and torque.
    I have hooked all vacuum line and everything seems to be plugged in.
    If anyone can point me in the right direction, it would be much appreciated.
    Thank you to all
    start checking fuses... also on my 3gee everything seemed to be good but it turned out that the little switches on the brake and clutch pedal arms were out of adjustment and were not allowing the cruise to set (or kicking it off over bumps)
    those switches might need to be re-adjusted
    RIP
    Bought from : LosiRacer2, h22anow
      Cruise control issue...
      I know for a complete fact that every one of my fuses are brand new. I usually switch out fuses every 3 years. I am very particular when it comes to electrical power within a car.
      I will check them out just to be on the safe side and I will double check the wiring and pedal adjustment.
      Thank you for your input.. will keep you updated.
        bump I have this same problem. My light comes on and the fuse is good. I'll check the adjustments on the brake/clutch I guess.
          You are using the manual cruise control computer right?
          "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
