interior overhead light
    my 91 ex, the overhead light will only work if i push or beat the hell out of the headliner,the door lights work fine. any suggestions
    country folks can survive
    "Cracker's crumble Honkies rumble"
    sounds like a short in the wiring up there.
      do you know precedure for accessing wires for the light
        do the same method you've been doing... jk
        *Needs*
        -New shocks
        -Struts
        -Drop
        -Cleaning
        -New Tires/Wheels
        -New Window Tint
        -Alot more lovin'
          i think if you remove the plastic piece so you can gain access to change the bulb, you should see some some screws so that you can remove the assembly. just check the connections there as something is probably corroded or the bulb might even be loose.
          out of curiosity, do you leave the dome light switch in the position where it only comes on when you open the door or do you flick it to the always on position?
            yea it could be just a loose bulb. could also be with the wiring up there. lets just hope that it's the bulb. cus if it has to do with the wires, get ready for the circuit tester, some more wire, solder, heat shrink tubing or elec. tape. ect. ect.
              Ehh , did you change the bulb to a new one?
              That worked for me lol.
              1996 Honda Civic LX 2009-2012
              2012 Kia Optima LX 2012-2013
