Not the main seal
    Not the main seal
    What is the name of this seal right here? Its not the main seal between the block and the tranny. I have many oil leaks in the red areas and a HUGE one just below my distributor cap.
    What should i do about it? I heard you can weld it or use a compound to seal it up. How much does it cost? Where do i get that seal?
    Any help is appreciated. Thank You
    nobody?
      The oil you see there is most likely from the distrubitor area and its leaking down to the bottom of the transmission. Get some pictures of the leak and then I can see whats leaking.
        yea, dont weld the case, lol.
        I <3 G60.
          if i remember correctly, there is paper gasket there. when they rebuild them, they usually use some sort of rtv silicone on there. but as others stated, most like from your distributor o ring or dripping on top if the tranny.
          Members Ride
