AC is not cold anymore and summer is comming
    My AC is the same as fan now.
    I was told the car used the old style refridgerant, which is no longer made.
    Is this true?
    I was told I would have to retrofit it with a newer style AC system.
    If so, what are good alternatives?
    You need to recharge the AC system.
    Raceline USA
      they dont make r-12 anymore.... but that dosent mean you cant take it to a ac shop and have it recharged... just becuase something isnt made anymore dosent mean you cant get your hands on it any more... the easiet thing to do is retrofit.. they sell the kit at advanced and autozone... but take it to a ac shop and let them do a leak test on it 1st... if you got a leak and retro fit all the frigedernt is going to leak right back out and thats just money out the pipes....
      Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
      But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
        I thought retrofit meant new AC unit all together.
          no it just means they replace your current old R12 freon w/ newer, more environmentally friendly R134-A freon. R12 is better and gets colder, but isn't as widely available now. They do make a Freeze12 I believe that can be used w/ R12 freon.... But yeah, have the mech. first put a dye in the system to diagnose for leaks and see if you have a leaking discharge line. Mine was leaking pretty bad and was noticeable after the mech. put this special dye in that shows up under a certain infrared light. He'll have you drive around for a day or two w/ the A/C on to circulate throughout the system and then you go back and he'll inspect w/ that light and see if its leaking or not.
            it means u need a new a/c set up or go turbo and role down the windows and just drive really fast.... thats what i did when my ac dide.
            now i was jk about the turbo but ya u need to update ur ac
            93 EX COUPE, F22A6 turbo project
            http://www.cb7tuner.com/vbb/showthre...45#post1615845
            96 lexus sc300 DD
            http://www.cb7tuner.com/vbb/showthread.php?t=143563
            back from basic.... off to ait.... CB still being worked on i have mad plans for it .. sorry cant tell its on the hush hush for now but all i can say in somewhere around 500 hp soon to come..
              are you sure your system has never been converted? Check the blue cap and see if it has threads on the inside or outside of the connector. IF it has it on the inside I bet it has already been concerted and you just need to get a refill kit. I highly recommend just getting a simple recharge kit that has a built in gauge and with refrigerant that has some oil and leak sealer in it. You will probably have to keep adding leak sealer and refrigerant for a while till it either clogs the leaks. Might take a few cans of that
              Let us know if it works.
              If you need to do a retrofit you should just go the simple route and get a kit for like $40.
              AD5OS
              FOLDING@home
                x2...it ain't that hard
                  I guess I'll change over to the new stuff.
                  apparently you need a license to legally buy R12.
                  I'm pretty sure my car has never been converted, it's a 93 and the ac has never been recharged.
                    I have had pretty good luck with Freeze 12 in one of my old dodges. Down and dirty I just put two cans in it and its on its 3rd year.
                    I use 134a in my 88 honda but I converted it myself and it works pretty well up to about the lows 90's then the performance kinda drops off.
                    wp
