steering problem
    steering problem
    hey guys im having some problems with my steering. when i get going 55+ mph my car starts swaying back and forth and my steering wheel feels loose and i can barely control it. could this be something messed up with my powering steering? thanks
    oh yea i just lowered it and before i lowered it, it didn't do this. could it be my camber bc its really bad? i haven't had a chance to get a camber kit.
      you probably really need a wheel alignment... when you lower these cars to much the wheel toe changes due to suspension geometry change... this can be bad for tires and wheel bearings... fix it quick with a wheel alignment at least or/and get a camber correction kit.
        How low are you dropped?
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          it happens to me when i reach 60 or 70ish. its probably bad camber. i havent had time to do an alignment or buy camber kits or anything so im pretty sure thats my problem which should be the same for you. get those done and you should be fine
          no
          Accord turbo kit under $2k here
          $30 HID kits here Thread
          "What a selfish bitch. She looks like one too. A smart-mouthed, facebook-ing, "i dont know if im straight, bi or *** yet" little brat." -greencb7inkc
          "No Herra Frush, Slammed, tucked or frame dragging here. I'll leave that to the mini trucks...." -fishdonotbounce
            scary isn't it lol, (cough) i've taking my integra up to 120mph(jdm ecu limits there) and it doesn't pull from side to side even with the -2.5~ degrees of camber it has due to like 3" drop... its the toe that will kick your ass if your not careful. on a side note, my car will want to do a automatic lane change if I'm on pavement that has mild ruts or uneven.
              wheel alignment.... plus do it soon because its gonna mess up your tires then if that happens your gonna need a new set of tires plus the alignment...
                well no one mentioned this though, but check to be safe.....check you sway bar endlink bushings in front to see if they're in good shape. Chances are, they're torn/cracked/worn beyond belief like mine were a couple years ago.
                  its pretty low im not sure how many inches. but its so low if im driving and i go around a corner the tire hits the fender well and shakes really bad.
                    ok guys thanks for all your help i'll get all that done asap.
