dash lights
    dash lights
    Can any1 tell me which lights are supposed to turn on when u turn the key in the ignition all the way? When I turn the key , the battery,oil and brake light turn on . Is the check engine light suppose to be on too? And does anyone know what bulb is used for the dash?
    Thanks
    alone in this game . ::My Ride My Way::
    cel is supposed to be on. they all are. then when you turn the engine over they should all go away
    ^^click it or ticket^^
      Yea the check engine light isn't on . I think the bulb burned out. I'm going to try to replace it now
        Bump
          anyone?!?!?!
            The CEL should only come on for a second or two, and then go off (NOT stay on, unless you have a code stored).
            So, if you aren't seeing it at all, then yes, the blub is probably burnt out.
            1992 Prelude S w/swapped H22A
              yea I figured it burnt out. I just checked my haynes manual and removing the guage is a biitch. ill change the bulb wen I really have to =]
                lol, when you really have to, you won't know....since the bulb will be burnt out. I'd suggest doing it now, its a pretty important bulb IMO.
                  did it used to turn on before? i had the situation where a friend of mine bought a car and didnt check this lil bulb. happened to be that the previous owner removed the bulb so it wouldn't like up and show the check engine light on. not cool
                    it is a pain to remove the console, but it worth it to have the CEL light working. i would do it as soon as u can. just my 2 cents
                    My Ride
                      since i bought it , it hasnt turned on. does anyone know what light bulb it is?
                      also, is the seatbelt light supposed to be turned on if u dont have your seat belt buckled? because that light isnt on either. mayb its burnt out too
