driver side axle removal
    i removed the driver side axle today. in the process of yanking it out , the joint in the middle came loose under the boot. Does this slide back in place or is the axle ruined?
    It should slide back in no problem, you may need to line it up and give it a wack with a hammer (with the axle nut on) but yes, you can just slide it back in. (i did it 3-4 times in one day and i havent had any problems.
    90 Accord EX F22a1 Auto R.I.P.
    2011 Mazda 3 Hatch 2.5L GS sport HELLO!
      just line it up should pop back in and be good to go
        what did you all have to take off to take the axle out? thanks
          i'm curious too, I need to replace an axle as well.
            search.. and you shall find..
            http://www.cb7tuner.com/vbb/showthre...highlight=axle
              I took off the tie rod, the damper ford, broke the ball joint from the lower control arm. remove the bolts holding the intermediate shaft and pry it out. Do not pull from the outside shaft like i did. The hardest part is the axle bolt out. 36mm, use long breaker bar or air gun. It was not so bad. This was my first time also. I am on my third day of my H22 swap. This site has been the motivation for me doing my own swap. Just search this site. 9 times out of 10, the answers are here.
