replacing engine with same stock one?
    Hi, i was just wondering witch way would be the right way to take the old engine out and replace it withe the same but lower milliaged engine.
    two ways of doing it. if you have a car lift you can drop the car on to the engine. or if you cant do that use an engine lift. and drop the engine with that into the engine bay.
      http://www.cb7tuner.com/vbb/showthre...&threadid=8849
      My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
      New people click here
        If you're replacing f-series for f-series, i dont see this taking more than 1 long day. Its literally, remove/install.
        Originally posted by Jarrett
          yeah i think the same way but i just wanted to see the right way to do it, thanks for all the help guys.
            Along with using the above link, and this might be too much, but its how I'D do it to ensure a quality, clean swap, but i would write everything down. Step by step. And as i install the new, id follow those steps.
            Just me though. GL with whatever happens.
              im just using that to get the major idea and something to fallback on or sum,basically im jsut gonna take off w/e is attched to the enigne and keep it to a mininum. since im automatic do i just take the bolts off from the tranny to the engine and take the axles out? thks again
                with the auto your better off just taking the trans bolts and starter and the bolts that hold the torque converter to the flex plate and leave the trans in.
                wat?
                  where would the bolts to the flex plate be located at?
