tranny help!!!
    tranny help!!!
    i'm new to the site
    i have a 93 accord sedan ex, i had my car on neutral and it juss shut off, when i turned it back on it feels stuck on 3rd gear. i tried shifting it off but it is still on 3rd gear i have no idea what it is. i have checked the shift linkages and cables and they look fine to me, anyone knows what can be wrong??
    thankzz
    MANGAMO RACING #2
    is it auto or 5 speed we need more 411
    The Race Car
      my bad its 5 speed
      MANGAMO RACING #2
        bump need help
        MANGAMO RACING #2
          i had the same problem but it was 5th gear.i could put it in first and 5th the shift fork broke off the shift rod in 5th it is inside the trans .getting a used trany is alot cheaper than fixing it unless you are diy hop it helps.
            Im confused.... is the shifter in neutral when you start the car and it will only shift into 3rd? Is the clutch working... you press it in and you are able to start but not shift out of 3rd?
            AD5OS
            FOLDING@home
