Rack n pinion help
    Rack n pinion help
    I just got done replacing my rack 'n' pinion on my '90 accord with one from Majestic Honda. I didn't use Honda power steering fluid but used Coastal honda P/S fluid til i can get some genuine fluid.
    My question is that, is the rack supposed to feels like a manual rack with alittle assist? It only feels like that under 5mph, like when i'm backing out of my driveway. When i taking off from a stop while making a turn the steering wheel feels much tighter than my last rack. I only replaced it becuase my original one was leaking. If i cross the two line for the speed sensitive steering would it cause this?
    Any help will be appreciated
    '90 Accord EX
    how many 1,XXX miles ago did you install the rack?
    UNDER CONSTRUCTION
      i guess is that you would have to adjust the pinion gear.
        it was install about 20 miles ago
        '90 Accord EX
          The speed sensor pipes are different sizes, so you shouldn't be able to swap them - But check them anyway
          My 5.7 LS1 Holden Ute
