If you have never driven a car with an aftermarket clutch be prepared they can be very harsh for those not used to them. I was driving my friends 95 eg hatch (b20b/b16 hybrid) with a stage 3 clutch and when I went to pull out of his garage I started to let off the clutch it threw my foot back (I didn't expect the resistance) and I left about 3 foot rubber marks in his garage going in reverse. First and last burn out I have ever done in reverse. Either way I also like the idea of the f22a6 with an h23 tranny. If you wanna race the car I suggest going with the h22 tranny it has the shortest gears, but the h23 tranny is a good comprimise if you don't want a full race setup. a 12 lb flywheel, a racing clutch the h23 tranny, a cam, a cai, a header back exhaust, and some valve work will make you very happy, I say the valve work because it will give you the ability to rev the motor up a bit higher safely.
h22/23 trans on a f22a6
I have the JDM H22 LSD 5spd trans mated to my F22ax motor and it does 3800 rpm at 80 mph in 5th gear. Get this or the H23 spd trans, whatever you can afford.
I highly suggest a better clutch than Exedy stage 1, again I repeat myself, go one step above what you THINK you need. I suggest one of Bisimoto's 1MS Action clutch kits.
