Coolant sensor locations
    I was looking through rock auto and found multiple switches. I found one that says its block mounted, but im not sure where this is located. Part number FOU 36557.
    Electrical Switch & Relay
    Radiator Fan Switch
    Last sensor on the list.
    I know about the one on the front of the motor as well as the one on the housing for the T-stat. Where is this other one located?
    90 Accord EX F22a1 Auto R.I.P.
    2011 Mazda 3 Hatch 2.5L GS sport HELLO!
    I belive the one your missing is the one under the distributor in the head ...
    In Need of an engine, just a basic f22a...pm me if you have one willing to part with.
      I bleieve i am. If thats where it is, i gotta take a look at that right away
        man, i cant believed i missed that one, no wonder its not working right, it has so much mud around it, and grime and shit, i bet the connector is fried as well as the sensor. Gonna replace both this weekend.
          I think it should only be bad when the CEL is on. I too thought mine was bad, but when I replaced it w/ another that was not oil soaked, it didn't change anything or solved any of my issues. but when the sensor is unplugged, you definitely get a CEL and the D4 light blinks.
            im just waiting for my rad fan to come on, so i can test it, if i pull that plug, and it stops my rad fan, im buying a new one.
              I think a way to test, according to my chilton's manual, is to take it to differenct temperatures and measure the resistance values it produces
                According to my manual (my brain) i cant remember wtf to do lol. If i unplug it, and it stops, im going to replace it. :P
                  Question about this sensor, is it the same as the one for the front Water outlet? If so, im going to replace it with my spare here.
                    All I know is I needed a 19mm deep socket to remove it, its the one underneath the dizzy. But be sure to have the other one in hand, b/c once you remove it, coolant starts to flow outta there
                      After finding out this issue is NOTHING to do with the cooling sytem, i have a BIG update on the situation.. My AC Condenser fan keeps kicking in, NOT the rad fan!!! *when looking at the engine, its the fan on the left. I pulled the AC condenser fuse, and look at that, the fan shuts off. Any clue what it could be?
                        Does anyone know what this is for? (and i mean the relay thats under the fusebox, i pulled it up for a better pic.)
                        Thanks
                          So i found out today, that relay is for the window motor. Someone was talking about a relay behind the glove box that will cause this to happen. CAN ANYONE SPECIFY OR CLEAR UP WHICH RELAY THAT IS, im going outside to try and find it ><
                          Found the relay i think...
                          What you guys think?
                            ttt, its an early bump, but this issue is draining my battery every day... anyone?
