okay, i stripped one of the screws to take the ignitor out, the phillips head ones, so I made a mark on the dizzy and the cyl. head so that the timing wasn't outta wack. But then forgot to make note of the relation of the dizzy to the cyl. head so the rotor is either pointing at cyl 1 or cyl 4? does it matter which way it was pointing? or should I rotate the crank to TDC and start from there?
okay took the dizzy out....now which way to put in? HELP!
97' Honda Odyssey 199k miles...$485 spare van for my parentsTags: None
it said something about the lugs being offset in my haynes manual so they can't be installed 180 degrees out of time. does that mean that they only go in one way? those two "lugs"?
theres a notch on the rotor, just make sure its lined up, don't force it
I forced the last one I installed because I couldn't see very well and put it in wrong, I thought it just needed some convincing and it snapped one of the little juts. So I had to swap the guts to a different one
yes exactly^^
it should be something like
They aren't dead center in the middle, they are offset a bit so there's only one proper way
its only meant to go one way so don't break it like I didLast edited by accordaffair; 05-01-2008, 12:34 AM.
Originally posted by Losiracer2okay, i stripped one of the screws to take the ignitor out, the phillips head ones, so I made a mark on the dizzy and the cyl. head so that the timing wasn't outta wack. But then forgot to make note of the relation of the dizzy to the cyl. head so the rotor is either pointing at cyl 1 or cyl 4? does it matter which way it was pointing? or should I rotate the crank to TDC and start from there?Take that freek show to the park, maybe the squirrels will care.
oh okay, yeah i figured it out, it only goes in one way, I'm stupid lol.
