I've been reading around these forums alot and have afew questions about my car. Its a 1990 ex. From what I understand it should have a F22A4, right? But sitting in my engine bay is a F22A1 that doesn't run very well, idle problems, CEL's, smoke, more idle problems, ect.... could some of these problems be because the car is actually sopposed to have the a4?? I've swaped out some jy parts to try to help but it seems worse. should i try a a4 ecu? or maybe it doesn't matter? Like i said " Im confused". I also have a f22a1 from a lude that I'm rebuilding to swap in, will I have the same problems with that motor? and one last question that seems kinda dumb: is there a difference between a auto ecu and the manual?
The Land Of Confusion
Originally posted by mj213I may be wrong but the f22a4 would have been stock.
The f22a1 was what came with the Prelude S
F22A4 specs:
Power (bhp@rpm): 130 @ 5,200 rpm
Torque (ft/lbs@rpm): 142 @ 4,000 rpm
F22A1 specs:
Power (bhp@rpm): 125 @ 5,200 rpm
Torque (ft/lbs@rpm): 137 @ 4,000 rpm
Hope this helps!
Engine model depends on Car model and origin.
F22A1 can be found in Accord DX and LX models.
If the original engine was an A4 and they swapped in the A1 w/o changing the ECU then, yes some problems could arise.
Also yes the manual/auto ECU's are different.
My 5.7 LS1 Holden Ute
Originally posted by bmxfelon420is there any way to check off of your vin to find out what originally came in the car? i have an a1 in my 91 lx, kinda curious.
the Prelude S has 135 HP not 125, since it has a P12 ECU that gives it a 10 hp bump, basically if you have the A1 in your accord, you could swap the P12 ECU into your accord and now have 135 hp. Its a common upgrade and SO simple to do. Plug and play 10 hp basically.
member's ride thread
91 Accord SE 176k
Originally posted by Scubasteve_dan
randomly swaping jy parts to a old car isn't that great of an idea.
To my knowledge, a4 has a better tubular header with 4-2-1 design which gives it the extra horse and lower end torque. Overall spec of the engine is almost the same (other than the header compare to a1).
difference between a4 and a1 ecu i think is the speed limiter, a1 has it, a4 doesn't, i believe a1 can run with a4 ecu without much problem.
Our cars have TCU, in theory, auto and manual can be mix and match, but sticking with original is better!
hopefully I helped
Vouch for: Jarhead293, 2.2litrebeater, Darkshadow707, slammed4thgen, Pacman91ex.
eh....again...pin point your problem first before you do things...
10hp is not gonna do much in a car that doesn't run well.
try seafoam sometime see if it can clean out ur manifold and help the idle problem.
for CEL...check the dyi section for code pulling....pull the code before you swap parts.
Or just do a compression test on ur engine see if it is worth your time
