vacuum lines
    vacuum lines
    ok i have a f22a1 in my 93 lx with the a6 intake manifold.. i know the person that put this motor in did it in less than a day and just threw it together.. does anyone have a diagram i can look at or a does anyone have this same setup i can compare vacuum lines to? thanks
    i kno its off ur topic but do u notice any power differance or anything???
    ~CB7 Phoenix~
    (picture missing help me get a new one )
    The California White Tux
    *and its alive!! hahaha*
    *under construction*M.R.T: http://www.cb7tuner.com/vbb/showthre...=1#post1689652 *changes soon to take over*
      Check under the hood, should be a diagram there...should be mostly similar with the a6
      Some one posted the vacuum diagram but I dunno if it was for the a6, do a quick search and you'll find it pretty easy.
      ____
        maybe the leak is from a gasket
          srry but i wanna know does that a6 mani boost up ur cars hp or tq anway kuz if it does then i wanna do this
          ~CB7 Phoenix~
            please don't thread jack...That EXACT question is covered SO MANY times.
            since this is the noob section and by the rules I must not simply say "search" I shall answer your question...
            yes it does, check the hp/tq specs for the a1 f22 vs a6 f22...you can potentially add 15-20...25??? hp over the f22a1 by swapping stock parts alone...I won't go into detail as a very short search will do you much more good than me handing the info out.
            ANd to the OP...
            If this engine was "thrown" together...vacuum lines are about to be the least of your issues. I would start with a can of TB cleaner, spray vacuum hoses...listen for RPM's changes or "hissing" changes where you spray.
            Check EVERY vacuum hole coming off the intake manifold, they should all be easy to spot...every vacuum lines begins at the intake manifold...follow them all...trace them all. Even with a diagram you would have to do this...mark the ones you've checked with a paint marker or white out.
            Check all the vacuum line connectors of course (like the check valve on the line going to the break booster...big ol vacuum line )
            Next would be to check ALL your intake gaskets...the TB to plenum...plenum to runners...runners to engine...
            Then you could check your IACV gasket, your FITV (to the right of the IACV), then the air booster valve...uh whatever it's called...(on the end and to the right of the FITV)...check to make sure your butterfly valve is closing in the tb...
            *sigh...basically if it was done improperly...you need to check everything they touched...and every sub piece of everything they touched...
            But I tend to overdo things so that's just my .02 on the matter.
            ____
