I had a 90 with a f22b2 already in it when i got it. I decided to take that motor and to put it into a 93 that i just bought. The motor is already in and is sitting perfect... I am now noticing that the connectors for the engine and body is different. Not only the connectors are different but so are wires. There are different amounts of wires and they are also different colors. I need help... please advise
93 f22b2 swap
Ya, I've personally torn-down a 92 F22A1 and a 94 F22B2 and some things are different in deed. Most of this is differences in outsourced parts, like the water pump and oil pump, however, they are similar in most aspects.
As for wiring, I'd start by comparing the wiring diagrams and determining if you can just rewire certain things, changing plugs where necessary. As for extra wires, the F22B2 has a crank position sensor that the F22A1 does not. Also, some sensors may be wired differently, requiring extra wires (like O2 maybe?) or you may need to just swap sensors between the two motors. As far as I can tell, the blocks are fairly similiar, if not the same, and most if not all sensors should be interchangeable (except non-existent sensors on the F22A1, like the crank position sensor). I personally recommend getting new sensors straight from Honda, but used sensors from a junkyard will also work.
Or hell, maybe all you need to do is take some parts from your 90 and swap em over to the 93 (wiring harnesses, ECU). Check out the wiring in your 90 Accord while your at it.
