Clutch Slave cylinder.
    I have to replace my slave cylinder case it's leaking fluid how do I replace it?
    About how long will it take?
    What tools will I need?
    I AM KOONCE THE LEGEND!!!
    you will need a flare nut wrench for whatever size the line is, i believe either a 10mm or 12mm.
    and either a 10mm or a 12mm ratchet and socket for the 2 bolts that hold it onto the tranny.
    should take no more then 10 minutes.
      make sure to bleed the system afterwards.
      My Members Ride Thread
        here follow this:
        http://www.cb7tuner.com/vbb/showthre...ighlight=slave
          Thx dudes shit helps a lot. yeah so it is as easy as I thought I just had to make ask advice to confirm that it is that easy. thx. oh one more question what is the MPG on a stock f22 if yll know
